Jan 22, 2025 6:45 PM UTC
Incoming Calls ringing busy
We are not able to receive any incoming calls.  The phone number just rings busy.
    Jan 22, 2025 6:52 PM UTC
    We’re having the same issue, I think it must be an outage
    Jan 22, 2025 6:57 PM UTC
    Can anyone even contact support? This is unacceptable
    We are having the same issue. I also cannot call tech support from my cell phone to report the issue.
    Jan 22, 2025 7:00 PM UTC
    tech support is not answering, after 20 mins their virtual assistant asked me to provide more details… ugh
    Jan 22, 2025 7:01 PM UTC
    Same here… Phones are not working for outgoing and incoming calls - Errrrrr
    Participating Frequently
    Jan 22, 2025 7:02 PM UTC
    Phones not working. This is unacceptable as we are an emergency response company. I think ring Centeral is about to loose a lot of clientele.
    Jan 22, 2025 7:03 PM UTC
    Nun of us on here could even get through to them, can you please inform them there are over 25 people on here that are trying to call them and they’re lines aren’t going through
    We’re all experiencing the same issues as well
    Jan 22, 2025 7:09 PM UTC
    Their website says that they acknowledge the outage and are working on it, but doesn’t really give an update.
    Jan 22, 2025 7:11 PM UTC
    Same issues inbound and outbound. This should be broadcast on their X.com channels.
