Jul 11, 2024 3:49 PM UTC
Incoming Calls Ringing on overhead paging system
How do I get my incoming calls to ring on our overhead paging system (Algo and CyberData)? This is for our retail stores where it’s hard to hear the diminutive ringers on our Poly desk phones.
    Found Your Voice
    Jul 11, 2024 5:05 PM UTC
    Both require a DL, so keep that in mind. You’ll pay for a full license to have this functionality.
    For CyberData and Algo
    • Create an “other phone” in Phones and Devices and grab the manual SIP provisioning info
    For CyberData:
    • Register your manual SIP settings via the SIP → Nightringer Settings tab. Plop the manual provisioning info there.
    • Add your NightRinger device via your RingCentral account to your Ring Group/Call Queue and it will ring overhead for incoming calls
    For Algo:
    • Register your manual SIP settings via Basic Settings → SIP → Ring/Alert Mode (ON) → Ring Extension (User Name) → Authentication ID (Auth ID) → Authentication PWD (RingCentral Other Phone Password).
    • Features → Ring/Alert Tone, Volume, Limit (Set this to your desired specifications)
    • Advanced Settings - Advanced SIP → SIP Transportation (Just leave as Auto) → Outbound Proxy (OutboundProxy settings)
    • You can either choose TLS or not via the Other Phone settings depending on your network setup
    Jul 12, 2024 3:12 PM UTC
    Nice one @tak-it1!
    @Goodwill IT, If it was helpful, consider marking it as the Best Answer. It really makes a difference! :)
    May 5, 2026 8:51 PM UTC
    What device do I build? Not seeing “other” as an option.
    May 6, 2026 4:08 PM UTC
    ​@pdunc, try this:
    • Go to Phone System > Phones & Devices > User Phones.
    • Click Add Device and choose a user (or create a "Store Ringer" user).
    • Select Other Phones > Existing Phone.
