Amplifying the VIBE
Aug 13, 2025 4:17 PM UTC
Missed Calls going to voicemail instead of callcenter
We just switched to ringcentral. For some of our incoming calls we use a callcenter service. That service uses their own non ring central-phone number that leads are calling into but it forwards/rings our ringcentral number first. If we don't pick up, the call center is supposed to get the call. Ever since we switched missed calls are going to our ring central voicemail instead of the call center. Anyone have an idea what is causing this? The service said that they have other customers using ring central without issues.
    Aug 18, 2025 10:04 PM UTC
    ​@Ad54
    When somebody calls your RingCentral number  our server responds with SIP 183 Session progress, followed immediately by 200 OK. This is expected behaviour and is necessary for us to support early media and E-Fax. You want to disable this, so that 200 OK is not being sent immediately - instead it should be sent only upon answering the call.
    There is a parameter on our backend called “Disable auto answering”. Reach out to support and get it toggled ON. ​@Mary-Community_Moderator might be able to help in raising a case.
    VERY IMPORTANT Requirements for this to work:
    - the RingCentral phone number needs to be a digital line. It will not work with an ALN (additional local number). For example a number assigned to a queue is not a digital line and will not work.
    I hope 516-471---- is a receptionist user extension that you have.
    - the phone number of the digital line needs to be set to “Voice only” as opposed to “Voice and Fax”. You can easily do this from Phone System > Phone numbers > click on a number.
    Side effects of disabling auto answering:
    E-Fax will not work, as the fax will be treated by the digital line as a voice call.
    Here is another common scenario where it is necessary to disable auto answering:
    Some two-step verification processes will send a code to a user through a phone call. When the call is sent to the RingCentral number, a SIP 200 is already sent on the call and the automated messaging system begins announcing the two-step verification code before the RingCentral user answers the phone call. By the time the call is answered, the RingCentral user is unable to hear the complete verification code.
    Your use case is a bit different, but I think what I said applies to your scenario as well.
    Joe Cache
    Aug 14, 2025 9:48 PM UTC
    This would be settings in your Call Queue:
    Under Call Handling and Members / Wait Settings
    Both of these options have the ‘Forward to an External Number’ option.
    If this service may change, I would make it an Extension and then forward the missed call to that extension (external number).  That way you can send all the Call Queues to that same (external) extension, and only have to change one extension should the service number change.
    That make sense?
    So - external extension would be 7000.
    In the call groups 1800, 2050, and 2100 - forward missed calls to 7000.
    if the service changes - you just have to change the external number on ext 7000.
    Let me know if that isn’t it at all as to what you are asking about - that’s how it read.
    You also have this setting on each normal extension - to send to an external number.
    Good luck.
    Aug 14, 2025 10:28 PM UTC
    That make sense?
    Good luck.
    You got it, ​@Joe Cache! Thanks for this! 😊
    Ad54Amplifying the VIBEAuthor
    Amplifying the VIBE
    Aug 18, 2025 2:08 PM UTC
    Doesn't seem to solve the issue. I got a response from our call center support team. It’s pretty technical so not sure if someone can help here.
    Their response"You'll need to contact your term provider for 516-471---- (ring central) to adjust the contact time of the 200 OK signal."
    For context, calls to 516-246----are connecting within 1 second, and a 200 OK response is being received at 0.762200 seconds, which from a SIP perspective means the call is connected. Because of this, it will not forward to the next number in the queue after 30 seconds.”
    ​@Ad54
    Amplifying the VIBE
    Aug 19, 2025 2:07 PM UTC
    Thanks so much. This is probably it. Basic support is claiming auto answer is already off. Is this a backend feature that only higher level support would know about.
    ​@Ad54
    Aug 19, 2025 2:25 PM UTC
    ​@Ad54
    Yes it is a backend feature and T1 support might have mistaken it with the front-end auto answering, which is something completely different.
    You could rephrase your request to support and ask them to have Service parameter 1156 set to Enabled. This way there is no confusion about it.
    Aug 19, 2025 3:21 PM UTC
    ​@Ad54
    Hi ​@Ad54, please send me a DM with your contact details so I can submit a ticket for you.
    Aug 19, 2025 3:24 PM UTC
    ​@Ad54
    ​@martintsankov Thanks so much for shedding some light on this! Really appreciate your help 🙌
    Amplifying the VIBE
    Aug 20, 2025 2:23 PM UTC
    ​@Ad54
    This solved the issue. Thank you Took a little effort to get someone to enable parameter 1156. But it worked.
    Aug 20, 2025 2:39 PM UTC
    Glad to hear that this is now resolved, ​@Ad54! 🙌
