Routing incoming calls through auto-receptionist only
A lot of our extensions are receiving a large amount of spam calls / fax. How do we block all incoming calls to the extensions, and force all calls to go through the main auto-receptionist line only? Anyone with success doing this?
Answer
October 19, 2020
Hello @Hari Ramsubramani! You can block the number. Click here! However, routing an incoming call from your extension going to the main auto-receptionist is not available. You can post this idea HERE. Thank you!
Answer
October 19, 2020
