Apr 13, 2026 6:09 PM UTC
Automating Call Transcription from RingCentral into Salesforce (Beyond Standard Auto-Summary)
Hi everyone,
I’m looking for some guidance on whether there’s a way to better automate call transcription from RingCentral into Salesforce.
We’re currently using the RingCentral Salesforce connector, and calls are logging into Salesforce successfully. However, we’re running into a limitation with the built-in AI auto summary, as it doesn’t consistently capture enough detail for our use case.
Current challenge:
  • Calls are being logged in Salesforce (Tasks)
  • Basic summaries are generated by RingCentral
  • However, agents still need to manually:
    • Enter a Case number in the “Related To” field
    • Ensure the call log is properly tied to the correct Salesforce Case
  • This manual step is causing inconsistency and extra admin work
What we’re trying to achieve:
Ideally, we want to:
  • Automatically attach full call transcription (not just summary) into Salesforce
  • Have transcripts stored directly on the related Case record
  • Reduce or eliminate the need for agents to manually link the call to the Case
  • Improve accuracy and completeness of conversation history in Salesforce
Questions:
  1. Is there a native way in RingCentral (or Salesforce integration settings) to automatically push full call transcripts into Salesforce, not just summaries?
  2. Has anyone successfully integrated RingCentral AI / RingSense transcripts directly into Salesforce Case records?
  3. Are there recommended tools (middleware like MuleSoft, Zapier, Tray.io, etc.) that can:
    • Capture RingCentral call transcripts
    • Automatically match/link them to Salesforce Cases (based on phone number, contact, or case logic)
  4. Any best practices to avoid manual “Related To” updates by agents?
Would appreciate any real-world setups or advice from anyone who’s solved this.
Thanks in advance!
Apr 23, 2026 4:20 PM UTC
Hello!
Specifically for the case match portion of your inquiry, we do have a feature that will assist with this. This is called “auto-link”. I have posted some articles below that detail what this feature does and how to enable it.
https://support.ringcentral.com/article-v2/Setting-up-RingCX-for-Salesforce.html?brand=RingCentral&product=RingCX&language=en_US#turning-on-auto-link
https://support.ringcentral.com/article-v2/using-auto-link-in-ringcx-for-salesforce.html?brand=RingCentral&product=RingCX&language=en_US
I do not believe we offer full transcripts out of the box, or to be able to write them to case records directly but there may be a solution available. For this, I recommend reaching out to your RingCentral Account Team (AE,CSM,TAM) to engage our Professional Services or Solutions Engineering team to explore any potential options to this.
