Aug 29, 2023 2:31 PM UTC
How to merge phone calls within RingCentral for Salesforce?
Can someone provide the step by step to merge phone calls within RingCentral for Salesforce? I did not find the instructions within the most recent user manual that I have.
Aug 30, 2023 3:11 PM UTC
Hey @Jeff Strickland , just wanted to give you an update that I'm still in the process of gathering the information you need.
Aug 30, 2023 4:49 PM UTC
Thank you.
Aug 31, 2023 2:53 PM UTC
Hi @Jeff Strickland,
If you're using the Browser as your calling option within CTI, unfortunately, there isn't a merge option available. However, if you opt to use the RingCentral app instead, merging calls is possible. Simply head to the Settings tab, select Calling, and then RC App to make the switch.
I've also received word from the Integrations Team that Conference calling, which includes merging calls, will be made available in the RingCentral Salesforce sometime in Q4.
Oct 18, 2023 11:22 AM UTC
@Mary-Community_Moderator
Do you have more information about the next release for the Salesforce merge function?
