Feb 21, 2019 1:15 PM UTC
Caller ID no longer showing on incoming calls forwarded to mobile calls
I blieve this is a bug on ringcentral as it started happening a couple of days ago. No setting was changed/updated and I went through trouble shooting with a customer service rep for 2 hours. I tested with another cell phone provider.
Reporting system bug:
Under Call handling & forwarding: I have the following set up:
Incoming calls forward in this order: simultaneously
1) Desktop & mobile apps
2) VVX-601 desk phone
3) Mobile phone
Then under Settings: Incoming Call Information: Display Incoming Caller ID is selected
However, on my mobile phone, Called Number is showing instead of Displayed Incoming Caller ID starting a couple of days ago.
Could you report this to the tech teams and get back to me?
Feb 21, 2019 2:21 PM UTC
Hey WON, I see you have case 08312094 open right now. Please continue to work with your Support Rep so that they can gather some more samples :) Once they gather what our higher tier support needs in order to do a deeper investigation, they should escalate your case (unless your current rep figures it out :) )
wonThe First StepAuthor
Feb 21, 2019 2:47 PM UTC
Hi, I spent a couple of hours and nothing worked. I think ringcentral should check if this is a system-wide issue as many people will not realize this.
Feb 26, 2019 12:06 AM UTC
This started happening to me as well around 4 days ago. I've made no changes to my settings.
Feb 26, 2019 1:08 AM UTC
Hmm, I see that I am not the only one...
Mar 1, 2019 1:06 AM UTC
Im having this issue as well. It started 2/14
Mar 1, 2019 3:39 PM UTC
Hey everyone, Support will need to investigate and gather more details :)
Mar 3, 2019 5:53 PM UTC
Mine too. And on my phone it initially shows up as potential spam
Mar 8, 2019 6:37 PM UTC
This is a known issue and there isn't a fix as of yet.  Just spent 45 mins on the phone with support to confirm that the issue lies in the Call Que because when you call the direct phone number of the landline the forwarded call displays caller ID info correctly.  I hope this gets fixed soon...we pay a premium price for this service and basic things like caller ID should be a non issue.
Mar 14, 2019 8:14 PM UTC
It has now been one full month of us experiencing this issue with no resolution.
Mar 14, 2019 8:47 PM UTC
Without notice the bug "fixed itself" 2 days ago at least for our account.
